LED Fog Light
SOlsenPHS
I need some serious help my friends!
I bought LED fog lights and LED head lights and decided to install them myself. The headlights went in like a breeze. The fog light on the throttle side went in no problem. The fog light on the other side has been a pain in the back side. I watched a Youtube video to see how and the guy says all I need to take off is a few push pins and pull the side trim out to reach the fog light cover. Well, I hit a snag, there is air intake hose right next to the cover and I could not get it off. I was afraid tat if I pull on the trim any more it will break something. I finally got the cover off and the bulb out, then new LED back in but I cannot get the Fog light bulb cover back on.
Any suggestions on how to make more room without breaking the tupperware or how to remove the tupperware around the fog lights?
Edit***I forgot, it is 2015 RT Limited
Please add a signature showing the year and model of your Spyder. After you do that, then we can help. Otherwise, we are flying blind.
Also -- It would help us to know which fog light are you installing?
It's doable. I did it.
Turn the wheels all the way to the left to give as much room as possible.
Try to slip the cover in using both hands at the same time to guide it. Use the left hand to push the cover down and the right hand to guide it into place.
It's doable, but you need to lubricate the cover with an ample amount of curse words.
Here is an update;
I loosen the air intake hose to give a little more room. Success!!!!! Got the fog light cover back on. BUT!!!!!
while snapping cover on, the air intake hose came off. apparently, I loosened just a little to much. Having a tough time getting it back on. Now I a remembering why I pay people to do this.
Stay tuned!!!
Here is an update;
Stay tuned!!!
Next up Date:
Got everything back together!!!!
Only had one screw left over!!!
Now to take it all apart again!!
I had the opposite problem. As soon as I pulled on the left panel, the hose came right off. It even had a hose clamp around it. Changing the light was easy after that. I guess I'd suggest looking for a clamp and loosen it. My new problem is getting the hose back on.
Was able to install LED fog/running lights in my RS. Nice improvement. Previous owner had upgraded the headlights to high/low LED's. I upgraded fog and fender tips ... and now the front of the bike is more visible and the lights are uniform. These are 30w bulbs and throw 7200lm of 6k light. Halogens were 35w bulbs ... so wanted something close. Inexpensive on amazon. Suparee brand.
