Lazer alignment $
lou49
Called a local dealer for a lazer alignment, and was quoted $ 349 plus tax! Then i mention S L and they discounted to $300! is this a fair price? Never done one, so i don't know what price they normally go for. Advise, anyone?
Most people that do the laser alignment (properly) get roughly $140.00 or less. Be sure that you get the true Laser Alignment, not the BRP alignment.
Cruzr Joe
WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT
It would be immensely helpful ( especially to you ) if you said who the Dealer was ????? .... then we could tell where you might want to take it instead >>>>> ..........Mike :thumbup:
They can't be using the Rolo system and charging that much. If they say they are using Rolo then they don't know how to use the equipment because it does not take 2 hours to do an alignment.
I rather not mike! I just won't give them my business! I wish squared away would make their way up this way! seems like they're the real deal!
Yikes...!!
The range is 120 to 150 but your quote is way off regardless of the system used..unless you are having other work included...🎯
Lou, we are both from Illinois and we'd be happy to come back when the winter is over. Just get a group together and we will get you squared away.
How often
​How often should you have this done? I just put on a new rear tire so should I have everything checked?
NOPE! NO OTHER WORK INCLUDED OTHER THAN BELT ALIGNMENT AND I BELIEVE THAT IS PART OF THE LAZER ALIGNMENT!
There's another thread here on lazer alignment that covers your question! i cant advise you, because i dont have the knowledge on that!
Lazer alignment
The short answer is yes. Anything that disturbs the rear axle affects (potentially) your alignment.
:yikes::yikes:
