Latest Farkle - Roadster Renovations Spring Stiffeners
robtdonna
Just installed a set. Simple , quick and absolutely do the job. :clap:Used in the A position so still have more adjust-ability. :yes:
Miracle nuts
I was going to start a thread about Doc's "Miracle Nuts" but never got to it.
They work. That tipping feeling you get in tight corners ... is gone.
And the fix took about 2 minutes.
I thought it was too simple to work and de-installed them and then reinstalled them. They work simply and completely.
I use Position #2 but can't honestly tell the difference between that and Position #1.
WOW. What a cheap fix!!!!!!!!!!!!!!!!!!!!!!!!
Glad you liked them! Our set now has bout 4k on them and still work the same! We even put a set on the rear to beef it up some to ease up on pressure to the air bag. I installed a set in the front in the A position on a '15 RTS the other day as well as a pair on the rear. He was new to a Spyder handling and this helped him with the control a bunch. Made his wife and him happy campers!
I was going to change them to "Miracle Nuts", but the wife says I can't! HA! HA!
Spring Stiffeners by Roadster Renovations
Does not matter Who's Nuts they are. They worked great on my 2013 RT Limited, it no longer has the squirmy feeling of driving on ice with under inflated tires. Thanks for a product that solved a complaint that I had with my Spyder since I rode it home for the first time, and I did not have to cut one of mine off, to be able to afford a set.
We are the New To RT Limited Peeps
That DOC is talking about in his post #5. The 2 Miracle Nuts on the rear shock are amazing. It will allow us "room" in the rear suspension to load up for a weekend trip.
Mike
Great Results!
I saw these a couple of weeks ago and thought I would get a set to see if they would stop the " Hula" dance our 2014 RT liked to do in corners. Wow! What a difference! She corners like a slot car now, no wobbles! Best bang for the buck of any product I have ever purchased for her. I HIGHLY recommend!
Just put them on today (position b) and rode 2up for about 50 miles. The dig in on corners is gone! My wife really felt it and is much more relaxed now when we corner. Install was super easy - it took longer to jack up the Spyder than it did to install them. Thanks folks for this GREAT product. Oh, this was on a 2014 RT-S. :clap::clap::clap::D
