CaptainBobby
What does it really do and is it worth it?
I bought a new 2014 RT and after reading on this site I figured out there are 3 things I need to do. Add a Custom Dynamics rear upper running/tail/turn signal light for safety, which is done. Add Rons sway bar which I did and it made a very good difference in cornering and some general handling. Get it laser alignment done which I did and it made a smoother handling Spyder. I would strongly recommend all three as I am very happy with the results.
I'm finding out the first 2014's are more apt to be out of alignment that were shipped to the south and the newer 2014 releases are much better. I think BRP made some changes on their assy line and are now doing a better job on alignment, but not perfect as mine took minor adjustments but enough to make a difference in the handling. Mine was one of the later 2014's released.
I say YES:yes::yes:What does it really do and is it worth it?
To answer the question. YES YES YES!!!!!!!!!
The ROLO alignment aligns your front wheels to the reader wheel. The original Can Am alignment aligned the front wheels to the frame. Your rear wheel has adjusters to get your belt to the proper tension and positioning, and it is likely that when your Spyder is delivered to you the reader wheel will not be perfectly lined up with the frame. Assume, for example, that the left edge of the reader wheel is slightly forward of the right side. Instead of the forward movement of the rear wheel pushing towards 12 o'clock, it is now pushing towards 2 o'clock. The front wheels think that straight should point to 12 o'clock, so you are going to continually fight the steering. And that doesn't even consider the problem when both front wheels are in a toe out condition.
I am one of the independent dealers, so I am biased about whether or not it is worth it, but after some of the bykes I have seen I would be running to get it done even if I wasn't a dealer.
To find a dealer you can go to www.SpyderComfort.com/dealers. You can also look on the first page of the forum and find links to those dealers who are also supporters of the forum should you wish to support those who are also supporting your access to this kind of information.
What they charge? My dealer is listed as doing robo aligns. I'm thinking of I having it done at the 600 mi check.
Cliff,
are you close to VA yet? Hurry up! I need my alignment.
ride safe, see you when you get here.[/QUOTE}
We are currently on track, I forget which week we were going to be in VA but it should be about what I originally told you. We will update you as we get closer.
