Laser Alignment
atitude2
I am planning on having the laser alignment done at spyderfest. I have read that the GloRyders must be removed before this is done and I am OK with that. What I was wondering is if the insert that the circuit board attaches to needs to be removed before being aligned. Thanks for any information.:dontknow:
You need to remove the whole GloRyder kit. You need to remove the circuit board in order to reach the 2 screws that hold the GloRyder in place, and that bracket inside the gap (that holds the whole GloRyder) needs to be removed as well. This is so we can get the laser spindle inside the rim's "hubcap" area, or the center area of the rim which is a gap.
