laser alignment
shoppersal
Who does this laser alignment? Does a dealer do it ? If a dealer does it I need the name of one around the Daytona Beach area, I need 1 front tire & we were just talking about they don't do front end alignments & read about the laser. Want to know more about it. Thanks.
Front tires should really be replaced in pairs. On another note, if one of your front tires is unevenly worn, but not so much the other, you probably have some worn or damaged sspension components. The ball joints, tie-rod ends, and A-frame bushings should be checked carefully, as should the wheel bearings. You may also have alignment problems, but I'm betting that isn't all.
