Laser alignment
I would suggest a phone call before adventuring out. 2 of the places listed in CA have been out of business a good number of years.
Who does Laser alignment in Texas?
I'm in El Paso right now, will be leaving in a few days
I would definitely ask pertinent questions if using a dealership for alignment. Most dealerships are stuck on the original service adjustments, such as belt tensions that are too high and result in vibration. If you use a dealership, ask them specifically what toe in they use, even if they use the ROLO system to align the bike. Spyders often come with not enough toe in, which causes them to wander or dart. OEM Spec is 0° ±0.2°. All the highly recommended alignment guys add more toe in to stabilize the bike. Make sure that is what you're getting. Of course if you use someone like Spyderpops, Joe at Squared Away, or Lamonster you don't have to worry about such as that.
We do laser alignments at our shop in Houston. Its a bit far from El Paso though. The rally in Kerrville would be much closer to you and Anne can get you squared away.
We will be in Kerrville for Spyders in the Hills in mid October. It is a great rally, take a ride down and we will get you Squared Away
I'm hoping to install new tires before arriving in Kerrville in Oct. I sure hope I can get on your schedule for alignment while at the Rally.
what should a laser alignment cost? the only indy dealer i can find near here [knoxville tn area] wants 170.00, seems a tad steep to me.
Ahhhh, why not upgrade to a LED headlight? The stock light is dim and yellow. We will be in Texas - take a look. Joe
Headlamp bulbs are not normally warranty items anyway. If you are going to pay for the labor to replace one, really should upgrade to LED and do both.
Road Warriors event, Trike’s and Spyder event. 31 October to 2 November, Deland, Fl. I’ll find a website. Joe
