Jetfixer
Well-known member
Hello All,
I've read many of the threads here about laser alignment. I have a couple of questions that I can't find the answers to. First, How long does a laser alignment last? It seems obvious to me that your laser alignment would only last until the rear tire needs to be replaced or any belt tension or tracking adjustment is made. Is this correct? Second, the service manual (2015 RT Limited) states that after alignment you must carry out a Steering Angle Sensor Reset, and a Torque Sensor Reset. Do the shops do this normally? Third, do they allow for the weight of a driver and normal front compartment load to be at the correct ride height as per the service manual? Fourth, would a necessary alignment not be a warranty item?
