MeudtPG
How many of you have installed these brackets on RT and NOT used the second bottom push pin hole because it does not line up after installing but instead used a wire tie?
Has anyone modified the bracket by grinding away some of the angle that keeps it away?
I am trying to get this to work perfect and have installed the lower bracket back behind against the metal frame instead of on top of the plastic and found it lines up better but do not understand why it hasn't been installed like that in the video.
Anyone care to comment on their experiences. I am a little stumped at how the lower deflectors don’t mount back on like they should.
I like perfection.
Thanks!
Paul
I like perfection.
Thanks!
Paul
