Lamonster Power Plate
The fuse near the battery was marked at the top with a "5", but it had two prongs. It that a ten amp fuse?
I yours says 5 then its a 5 amp.
FYI-
Do not put a larger fuse in as there are other factors to determine fuse size. Ex: Wire size etc. Could cause more problems by increasing the circuit protection (Fuse)
OK
Thanks Trikermutha. I did replace the original fuse with a 5 amp fuse and will follow your advise to not increase the amps.
Curious that at least one power plate came with a ten amp
Stick with what came with the unit unless advised otherwise.
Wire size,specs on the USB can make the difference on what it is rated at for what it can handle .
Not enough information on the ten amp post to comment
Good Luck :thumbup:
We have revised the power plate power line. We now remove the glass fuse and replace it with the posi-loc fuse holder with a 7.5 amp fuse. The 18 gauge wire can carry 7.5 amp continuously and there is no need to have two fuses.
