Hi,
For those of you that are using the IPS PackRack on your Ryker, does the aft end of the rack have any up/down movement? I just received mine a few minutes ago and was concerned about the excessive movement, so I called Lamonster Garage and was told to place a small piece of rubber on the “L-Bracket” to act as a shim. On further inspection the bracket doesn’t appear to actually go under/engage the Max Mount. It just kind of rests in the aft Max Mount slot. I’m worried about the rack departing after the first good bump.
Thanks,
Bill
Thanks,
Bill
