LaMonster Floorboards
bcraig
Has anyone gone back to pegs after installing the floorboards? Any issues with using the floorboards? Does the Cant angle adjust enough to make them comfortable for long rides? Is the outside edge of the floorboard adjustable to angle up so you can plant your foot to counteract lateral forces in turns?
Installed the boards about 2 weeks ago. Very satisfied, no desire to return to pegs.
There is some adjustment but you also have to leave room for range of travel on brake pedal. It is fine for me, never ride more than 60-90 minutes at a time here.
The outside edge of the floorboards is not adjustable though I would imagine it could be raised slightly by using washers. I have not had difficulty in turns, guess the angle would be more of an issue if riding at high speeds.
I like the idea of a floor board but IMHO whats out there is way over priced
They are metal, well made, and packaged with care. Not inexpensive but not at the high end of accessory pricing.
I have heard that some people are purchasing aftermarket boards only (no mounting brackets, no adjustability, generic boards) off amazon for around $60/pair. They then drill holes and mount directly to the top of the footpegs. That might be an option if the LaMonster boards do not suit you. Think it was these:
https://www.amazon.com/Flameer-Stre...r+floorboards&qid=1567358043&s=gateway&sr=8-1
Anybody got an pictures showing a rider using floorboards? Curious as to how the leg position looks
Given the angle of floor boards, should there not be a heel stop so your foot stays anchored on the board?
here u go;
locked heel at back end: 20200305_103444.jpg
mid-way w/toe on peg: 20200305_103524.jpg
SPYD3R-MAN DAN
Hi Craig on a previous post , I said I don't like floorboards , you cannot get any force behind your feet , when heavy braking like you can with pegs and the answer to your ? Is yes Lamonster will do all that
