Check out Lamonster's video. It covers that.
Now that I have them in hand you are correct. This would be the process.
-> Adjust pegs where you would normally ride.
-> Flip up stock peg and move brake pedal all the way up and lock in.
-> Remove stock peg
-> Install new cam over bracket
-> Cam down with tool to be determined
-> Bolt up new floorboard or peg
Like any other Spyder or bike you most likely move it one time and that's it. The floorboard gives you much more room to move your feet so it would be better than a peg for that reason. If you think you're going to move it all the time this is not for you.
The reason you were referred to the video is he explains your question in detail. Why would you prefer second hand information?
..... user feedback, rightfully, killed the OS.....
And in this case, it's user feedback which is, quite rightly, telling you that the easiest/most comprehensive way for you to understand the floorboard/brake pedal interaction is to watch the vid. :shocked:
It's not really all that long or difficult to see what's involved on the vid; it's even fairly straight forward to watch, but to explain it properly in text would be fairly long, difficult, & potentially quite misleading due to the various components.... yes, you do have to adjust the brake pedal 'differently' with the floorboards, but it's not as cut & dried as you seem to want it to be! So watching the vid is probably the best & easiest way for you to see exactly what's involved without getting confused or mislead by how it's written or what you read into what's written - cos we'd hate for you to go away with the wrong idea of what's involved.![]()
Don't worry, I'm not going away with the wrong idea of the product, just going away
Everything else I have ridden has had foot pegs so my experience is limited. How do the floor boards help and what advantage would they provide; besides looking freaking great!
You will NOT be missed!
............On my 18 RTL, if you have to slam on the brakes hard, the floorboard is made to shift down to allow for more brake pedal movement........
So please, let's leave it at that & get back on topic - Lamonster Floorboards on Rykers.
