Lamonster Approved Wheel Balancers for your Spyder
Not sure why you say I feel otherwise. Sadly, what we have here is a difference of opinion as to what constitutes a defective tire. .
Sorry
for my failure to communicate. I think you got though anyway. We feel the out of balance and out of round Kendas are defective. You seem to agree with that. BRP does not. I do not think its right, I also do not think I can do a darn thing to change BRPs mind. BUT I can have great tires on my and my customers bikes that do not have these problems.
It's actually the USE of the vehicle & driving on the road rather than tire wear per se that leads car & tire manufacturers to recommend that you get your wheel alignment & tire balancing done regularly throughout the life of your tires! Here in Aust, the recommendation is currently to get a wheel alignment & balance done whenever you fit new tires & then get them checked at least every 6 months or 10,000km; & also to always get them checked after a significant impact on a kerb or pothole etc - if an impact jars you so much that you hurt, even if only for an instant, then you should get your wheel alignment & tire balances checked!! :lecturef_smilie:
Here, we can access tire life warranties of up to 100,000km IF we comply with that regular balance & wheel alignment check regime, usually for a very reasonable cost - for the wheels on my 4WD's it's only $50 to check the balance on all the wheels (inc both spares) plus doing the w/align, so over the life of a set of 6 tires it's LESS than the cost of just one new tire!! And if you run Centramatics or similar, the balance requirement is waived & it's significantly cheaper for the w/a check alone!! I'd even go so far as to suggest that most Heavy Trucks & commercial vehicles that have a good safety & roadworthiness record here in Aus either already use Centramatics or similar devices, or they get their tires regularly balanced & their wheel alignments checked.... Just Sayin' :thumbup:
kenda does make some good tires, truck & trailer tires. but i hear a lot of complaints about them on here & on the
indian forum. when i installed some new kenda's for a member here i did see problems in them when balancing & 1 could not
be balanced at all. the more i see & hear of kenda tires for bikes the more i feel i will change them when mine are low, i think
i will be going with vredstein. i have not had problems with mine & i have 9k on them, i don't do a lot of mileage so i will be
changing them because of age next year.
I installed the yokohama tire at discount tire for 8.00 and removed 12 of those sticky weights of of the rim. I put the centramatic on and it is smooth as I can tell at 24psi. Was I supposed to leave the 12 weights on there? It has no bounce or anything. Wanted the hydroedge, but discontinued.
from what I understand the weights should be left on as you have must have got lucky because you are saying the front dont shake while driving
The weights were for the Kenda. I would have suggested balancing the new tire prior to mounting the wheel on the bike but yours turned out fine. If its smooth, leave it be.
Never seen these before, what makes them worth $100 ea?
Ive had my Spyder 5 years, still have factory front tires, on my second rear tire.
Never had an unbalanced feeling, nor unusual tire wear since I originally laser aligned my bike.
Just wondering how this is worth it over balancing? Can do a lot of balancing for $300. Lol
You sure CAN do a lot of balancing of OEM tyres for $300, Snoopy, but for those of us who, for whatever reason, have moved to 3rd party car tyres and don’t have a Can Am dealer to fit them, balancing can present issues for the tyre shops. The Centramatics are a one off purchase, address the issues where tyre shops may damage your hub if they aren’t careful balancing, and for me, provide excellent value for money.
Pete
Ah, so an issue with balancing or an issue w non-motorcycle tires.
I couldn’t find a tire shop who could mount my new rear tire and had to take it to a BRP dealer, who seemed to balance it fine.
Maybe fronts would be an issue on mine, don’t know yet.
Yeah, the tyre shop was worried about their balancer damaging the integrated F3 hub, Snoopy.
My dealer (200km away) would not replace the Kenda with a Kuhmo, so I had to do it myself. I could have had the rear balanced at a local motorbike shop, but their balancer was broken at the time, and they were waiting for a part from overseas, so I left the rear unbalanced and went with Lamonster’s Centramatics.....figured I may as well go with them on all 3 wheels, even though the tyre shop was able to balance the fronts safely. Overkill perhaps, but hey ;)
Pete
