Kwelmetal Highway Brackets - help ??
Dragonrider
Do the brackets fit UNDER the Spyder - left bracket for right peg and right bracket for the left?? or do I have the wrong set???? :helpsmilie:
Brackets fit under the :spyder2: just after the bottom matt black air dam with the small lip of the bracket faceing towards the back tire. Once installed these are one tough bracket easily supporting your weight.
The brackets fit on each side of the engine, using the same bolt as the enginee mounts. You've got to take off a bunch of plastic to mount them, but there's no cutting or trimming needed. PM me if you need more.
john
Thanx - getting under the Spyder is tough on the knees... but once under it, it was easier to see how they fit... it today's project!
