Kuryakyn grips with Throttlemeisters
Blinc
I have the Throttlemeisters installed now with my stock grips, but would like to change my grips out to the Kuryakyn, does anyone know if I can do that, meaning will it all fit together?
You'll have to open up the end of the grip a bit but it will work.
picture.php
picture.php
Oh nice Lamonster,
I'll order them up then. You have the cool billeted units I see, those were not available at the time of my order, bummer.
Thanks again sir!
I have the same grips but like the wrist rest & helmet locks. So I use the $22 throttle lock instead. You can hardly see it, it's easy to install, and you can buy it anywhere. It's the standard 7/8s unit.
These are universal 7/8. Kuryakyn now makes ISO grips for the :spyder2:
They are #6241. They may be shorter than the Universal 7/8 grips. If they are the ThrottleMeister install would be the same as stock grips. Using the universal ISO to make the TM work. It comes in contact with the end of the grip instead of the throttle tube... I learned this the hard way :roflblack:
