blackcrowe
klunky shifting (2014 ST Limited SE5)
Thanks again, I appreciate all your replies...
I should have made it clear earlier that I have the SE5, Rotax 998cc. Maybe you guys replying that shift into the 5500 to 6k RPMs have the manual shift and it might be different I don't know. But I took it out today and 1st to 2nd klunks no matter F'n RPM I'm at (sorry but I'm PO'd right now). I tried shifting over 5k - 5500 range and at that RPM the bike is screaming in 1st. That 5k-5500 RPM range is equivalent to about 35 MPH which is what I have to get to in order to shift to 2nd? so driving through areas where the speed limit is 25 MPH means I'm 10 miles over the speed limit before I'm going into 2nd. Maybe you guys who are shifting at that 5-6k RPM do have the SM5 or maybe the RT or RS are different.
After much playing around today this is what works for me and can get a smooth gear shift in the later gears, so essentially Can Am was correct in stating between 4 - 5k. Getting into the 5-6k range I'm practically gunning the bike every time to shift gears.
1st - 2nd = WTF?
2nd - 3rd = 4200 RPMs
3rd - 4th = 4200-4800 RPMs
4th - 5th = 4800 RPMs
So I guess I need to contact the dealer. OK so there is a klunk from neutral to 1st or to reverse but the 1st to 2nd is troublesome to me.
1st - 2nd = WTF?
