key ring hole
Dray
My 2015 F3S keys do not have a hole in the body for a
key ring. Can I safely drill a hole in the top of the key
with out messing up the security chip? I would like to
hang my gate and door opener on the keys if possible.
Thanks in advance.
Dray
Yup! :thumbup:
attachment.php
If you take a pin, it's easy to find the spot to drill; the pin will push right through the key, and happily bury itself into our other hand... :yikes:
Thanks in advance.
Dray
Short answer... Yes. Here it is straight from the master himself.
RING THRU KEY
AND WE ARE ABSOLUTELY SURE THAT BRP HASN'T CHANGED THE CHIP POSITION WITH THEIR NEW MODULE ???? just a thought............Mike :bbq:
And then....
There are a lot of nice key holders that give you the key ring option without having to drill a hole in the key. I use the sheath which works well and has the key ring hole at the bottom....choices choices...:dontknow:
Yup! :thumbup:
attachment.php
Fyi few options for keyrings
attachment.php
attachment.php
& my fave keyport:
attachment.php
https://mykeyport.com beware on drilling as the chip is super fragile & better to clone first!
