sandrunr1
I wasn't going to say anything because it was so stupid. Friday I went into Las Vegas to go to the movies to see Battleship. I parked and took off the helmet and put it in the Frunk. I turned the handle bars and locked them, then took the key out and as always was going to put in my pocket. For some stupid reason I put it in my vest pocket. Then I took the vest off and put in the Frunk. As I let go of the lid to close, I thought where did I put the key. As it locked I remembered. Looking around I said to myself in a nasty way, I will deal with it when I come back from the movie. When the movie was over, and it was very good by the way, kept me from thinking about the key, I went back to good ole bad name Spyder. At first I thought I will just grab the lid and yank it open. Doesnt work. Call AAA. All they would do is bring a big bar to pry it open. Then the bulb brightened. I took off the side cover for oil checking. Between the coil, exhaust pipe and the top cover, there is just enough room to slip an arm in and up to grab the cable which lays just about 15 inches inside. I grabbed the sheath and gave a little tug and walla, frunk popped right open. Spyder lost its bad name and I was very pleased. Lucky too. Spyders forever.
pps:
