Just purchased a new Brp trailer. ... so excited!
dmfahie
Can't wait.... getting hitch and wiring installed for new trailer to take to spyderquest in ny.... can't Reem the model#... has a front and rear door.. hold 150lbs... any words of wisdom?
If it has both doors it is a RT622, and you will love it. Words of wisdom, the only time you know it is behind you is when you are trying to back up. My dear friend, the late Butch Anderson, taught me that it is much easier to back out of a parking spot then it is to back in to one. Lots of little corrections right and left as opposed to a single large correction will keep you from jackknifing. If all else fails, look for a pull through spot or disconnect the trailer.
Make sure that the trailer has the latest grounding harness on it if not you may blow out your wiring harness on the Spyder.
