Tierhog
2008 GS/SM5 with green filter, HMF pipe and new Honda gaskets and JB Pro.
Changed battery and now have mild sputtering at 3000-4000 rpm. Idle..smooth as silk...above 4k smooth as well. Will diminish some as engine warms Up. Will disappear if i roll on the throttle. Everything was installed and set in 80-90F weather...
It's in the 40s and 50s now. Perhaps enrich the midrange from 0 to 1? I'm running the PC 5 tune in slot 4.
Is this a case of cooler temps and dense air entering engine. Does the JB override the OEM adaptation given the ambient temp?
I don't have an AFR so like many others its trial and error. I appreciate your insight...Spyder has 10,800 miles...12k service done except plugs and wires.... (I know Baja..I'm procrastinating).
Thanks!
Thanks!
