Joel the biker recommended LED
I rode for a little more than an hour after dark. They are a big improvement over the original lights but I want more! They do light up the sides of the road much better and you can see farther down the road but not enough to go more than 50 MPH at night. They should be much more noticeable in the daytime as well.
I drive a Nissan Frontier pickup and the headlights on it are EXCELLENT after I put in these bulbs: http://www.osram-americas.com/en-us/products/automotive/Pages/silverstar-ultra.aspx. They were good before and these made it almost as good as HID lights.
Of course, a lot of the efficiency of headlights is due to the design of the reflector. A really good bulb may only make a modest improvement in a poorly designed reflector and may not be as good as a mediocre bulb in a well designed one.
I think I'll see how much of an improvement the Silver Star Ultras make on the fog lights in a week or so. If I do and they're a good improvement, I may just try them for the headlights to see which are best.
LED lights Flicker
OK I put them in and the RH would flicker so I tore it dn and checked the connection. They still flicker so I removed them and went to Walmart and bought the Silver star Ultras and they are bright and don't flicker. "DUH" Way brighter than stock yellow lights.
The H11 LED fog lights seem to work OK. No flicker. So I would NOT suggest anyone with a 998 to get these. JMHO.
Mine is a 2013 RT-S SE5 and I don't have a problem with any flickering. They are imported from China and it probably goes without saying that quality control isn't one of their highest priorities.
LED lights Flicker
Sorry I forgot to mention my bike. I have a 2012 RT-S SM5 998. Joel I believe you have a lot of time involved in this. Im only giving my experience on this.
Im gonna let my friend try these bulbs on his 2011 RTL SE5 998 to see if he has same problem. I have more time than money so it wasn't a problem to tear down the bike several times. I haven't been out in the dark yet as today was oil change day. And I'm still trying to find a leak from clutch. Its dripping on my floor and I no likie...
It would be nice if you could make note of the bulb that is flickering and see if it does the same in your friend's bike. That would be an indication of a problem with the bulb rather than it being a problem with the 998. As I said, I've no problem with mine but I've only got a little over an hour of ride time on them. Thanks, Bob.
Ok, here they are:
Spyder RS and GS headlights http://www.ebay.com/itm/YITA-H7-120W...1XkJpY&vxp=mtr
Spyder F3 and ST headlights http://www.ebay.com/itm/YITA-2pcs-80...dZHU4H&vxp=mtr
Spyder RT headlights http://www.ebay.com/itm/YITA-2PCS-12...xXbKoL&vxp=mtr
Spyder RT foglights http://www.ebay.com/itm/YITA-H11-LED...xXbitY&vxp=mtr
NOTE: The cam plate on the bulb can be removed to fit the rubber cover on the back of headlights. On the RT, the stock hard cover fits, but its tight.
