Dizneyman
A little history here...When I first purchased my RTS, I had an issue where the air was leaking form the air bag, so the airbag was replaced. Spyder seemed fine for a few weeks when riding single or with both me and wife. Was able to adjust ride either hard or soy, no issues. Then on a long ride, the bike seemed extremely stiff. When I hit the adjust button, it was in manual mode with the left side orange. I took it to the dealer and the said a nut was off on some arm that the Spyder used to know where level was. This caused the pump to run and filled my bag to over 100 lbs..."ouch". They fixed it and it seemed fine for a few weeks. Then the same issue happened again, and this time they use loctite and a nylon lock nut. Again, all fine for a bit. Now the new issue"
Riding solo, all is fine.
Riding with wife, Spyder goes into manual mode.
I am able to add or let out air with switch. (even though in manual mode). If I add air, owlet a lot out, when stopping bike then getting on again, the bar has moved to correct location, but afet about a mile, back to manual mode.
ACS Position SensorChanged.
Pressure Valve CHanged.
Waiting to hear back what parts they will try now. I did notice some wires going into the seat. Is that a switch of some sort that tells the spyder there is two ryders, and do you think that could be the cause? I feel the pump may be bad from all the above issues, and just can not get enough pressure to fill the bag with two ryders, and the system gives up????
Only other thing is my cluster was changed a while back, and dealer says maybe that is the problem. I really do not think so as when I ride solo, no issue.
Sorry for being so long winded, but I have been trying to figure this out. Good news, it does not stop us from riding!!:yes:
Appreciate any ideas...
Rich
Rich
