ISCI fan can vs spyderpops air management system
SpyderRx
My question is which is better or can you do both. Have not seen the fan can installed so not sure how it works. I have spyderpops missing air dam and heat shield but still get a good bit of heat (both sides). I removed the plastic plate on the bottom, rear one, but should I remove the front one on each side too? Wasnt sure since the front of it curves up toward the radiator Did not want ro mess up the airflow going through the radiator. Any help would be appreciated.
I am interested too... The ISCI I believe kicks the air down versus out the side, I believe. Hopefully someone will confirm.. anyone ?
The Fancan I had on my RT put the air directly towards the engine and not down. I removed it because it made my seat much hotter. I use the Spyderpops blockoff plates with a hole in the swoop area that seems to work fine.
Hole in swoop area?
PLease explain further...
I use the Fan Can and the Spyder Pops. I have no problem at all with the seat being hot. I have a RTS 2011 and have put many miles on while using the fan can. You know how hot this summer was. Hope this helps. Bob
