Don't the 2014's come with a 622 trailer lock key barrel in the glove box to fit your key like the 2013's did? Or is that what you need to know, how toswap out the key barrel?Just realized I need to rekey my 622 trailer to the new ryde. Been looking but have not found the magic thread?
Finally got a chance to spend a whole afternoon on the AWESOME new RT L!:clap:
1. Remove inner panelsThanks everyone for your thoughts. Have the new barrel but getting the old one out isn't as easy installing the first one. Nearest dealer is over a hundred miles away. Will probably disassemble the interior trim as see what I can do. Still have one of the old keys so I am not sol. Still waiting on the new wiring harness to arrive anyway.
If you don't want to go to the dealer, I would still recommend purchasing a trailer shop manual online (or RT manual if it also has the trailer manual).
Our RT-622 (used) did not come with a key so I had to get a new barrel and key set from Can Am, mainly because I wanted the proper lock and key for it.
Removing all of the panels to get to the lock wasn't too bad. No shop manual here. I just started unscrewing and if anything looked bound up somewhere I just paid attention to any fasteners that looked like they may be causing it. Once I had all that apart, the cables were easy to undo.
The tricky part is under the silver plate that you need to remove. There is a ball bearing and a small spring that will pop out and land in the bottom of the trailer if you aren't paying attention... yep, that's how I know. I did find them and with a little help from some grease, the will hold in place while you re-assemble the plate.
The tricky part is removing the lock itself. It pushes to the outside of the trailer. In the picture you will see the small tab that you need to push down to start it moving forward.
If you have the old key, it should slide right out. If not, well, if you are extremely lucky you can use your Spyder key to get most of the pins to pull in and if you sort of move your key in and out you may be able to work it sort of like a bump key to get the lock to slide out... I ended up using 2 different Spyder keys (since we have 2) as each would get certain pins all the way in or mostly in and working with both of them I was able to get the old lock to slip out.
I probably got extremely lucky, but it did work. A locksmith could probably get all of the pins to pull in for you too with their proper tools, but I am cheap and wanted to do it myself. That and the tech at the dealership didn't really know how to get it out without the matched key.
In the pics you can see the fully locked mechanism has 2 main pins and the retaining pin on the back. The second shows the pins pulled partially pulled in by an incorrect key. The correct key would pull the pins all the way in to allow the lock to slide out.
View attachment 86375View attachment 86376
Ok, here's where I'm at, the lock mechanism out of the trailer but the barrel still in assembly, see photos, what's next ????
Thank-you!!
View attachment 96902 View attachment 96903
There is a release that needs to be pushed to allow the lock to push out, it was not difficult with the lock in the stage you have it.
i know this is old thread but I wo like to know if you have to remove the tumbler from trailer to switch key for a different bike?If I was there it would be easy, but I took the cover plate off, put the key in the lock and was able to see the release when I turned the lock. I believe I depress it and the lock cylinder pulled out. If you disconnect the cables and bring it to a dealer they would likely release it for no charge as it is a 1 second process.
Any local locksmith can do it.
Cruzr Joe
I R one
Apprenteced with a locksmith in my younger days. That lock is super easy to pick FYI as all the others on ther spyder. Good thing the ignition is chipped because of that.
Bob
You are as handy as a swiss army knife. :thumbup: (and you probably have one, don't you?)
Cruzr Joe
