mikthebik
This maybe should be in shop talk, but applies to both F3's and late model RT's.
I realize Baja Ron has a rewind fitting that fits the face of the Brembo rear piston, but I'd like to find a rewind tool set like
https://tinyurl.com/y747m5cy that covers multiple vehicles.
We have a Mini Cooper that uses the same type of screw-in retraction piston. I've done the brakes on it and borrowed the following tool set from a friend (https://tinyurl.com/yc4hubs7) that worked on the Mini's rear calipers. It does not, however, have the proper fitting for the Spyder's Brembo piston. The first set I listed is typical of those found on Amazon with a larger selection of fittings than the second, the one that I borrowed. Has anyone purchased a set like the first and successfully used it for the Spyder's rear caliper? :dontknow:
ray:
