Can someone verify that if you hold the throttle wide open and rank the starter that it turns over but does not fire? Mine has been put away for over a month and I had taken the battery out.
Drown mode is a somewhat hidden function performed by the 900 ACE engine in the watercraft, side x sides, snowmobiles, and some of the other BRP 4 stroke engines.
Long story short, I'm buying a valve that replaces to oil plug on this engine (in my Maverick X3) and would like to know if I should get a 2nd one now. It makes oil changes a breeze but makes use of the above mentioned function to remove all oil via the primary plug, and the small plug just stays intact. I just changed the Ryker oil before putting it away and I know its a mild PITA and make a bit of a mess. With this, no mess.
https://curtisvalves.com/products/utv-valves/
