Is the oem drive belt carbon fiber
I don't have a Ryker, but I have a lot of miles on rubber band drive scooters, mostly a Yamaha T-max which is a big powerful scooter. The recommended change on the Max is 12,500 miles and I adhere to it. In the belt failures I have experienced there were no warning signs. No squeak, no slip, just pow, and I was walking. Eyeballing a belt means little since most of them show little wear before they fail. When it fails it will shred and bits of it will goober up the centrifugal clutch, sliding pulley halves, rear pulley, and loading spring. It can also disrupt the position of the rollers in the variator, which will make the CVT not work right anymore after the belt change. So the entire thing needs to come apart to have every last bit of rubber removed, everything cleaned, all the rollers checked, everything aligned, etc. This make for a VERY long replacement job and a lot of extra work- if you replace the belt BEFORE it breaks and shreds, you can save a lot of time and money in the long run. You will walk if it breaks because this is not something you can fix at the side of the road.
