Is it normal for Ryker handle bars to move up & down?
Is It normal to have some up and down play on the Ryker handle bars?
Up and down motion can be fixed...
Remove Black plug #130, best with screwdriver and small needle nose pliers to get it completely out of stem channel.
Back out #702 bolt with a 13mm socket
This is suppose to be a FLANGED bolt, look closely at picture, (washer/bolt one piece) mine's not (2019 Rally) it has a separate washer. If yours is missing, the bolt may be bottoming out. I never did measure the washer but it's probably 2mm thick. (Trip to ACE?) If it's there, adding another washer I don't think would hurt. That's up to you.
Torque to 18 ft/lbs while reassembling.
Screen shot is from https://www.cheapcycleparts.com/oemp...rts?dropdown=t
