Nudels2u75
I have the Limited spyder, and I am curious to which oil to use.....I was wanting to use the Mobile One Motor Oil
I switched to Mobil 1 10-40 synthetic in my 2011 RS-S SE-5. It is JASO MA for wet clutches. My bike seems to shift much smoother now. Have had no clutch splipping at all. According to the Mobil 1 rep. in Sturgis, all synthetic motorcycle brands except Amzoil use Mobil 1 as their base. So you should have no problems either.
It does not "meet or exceed all the BRP requirements" since it was labelled API-SM. BRP specifically prhibits the use of these oils in the Spyder. Read your manual. Use Mobil1 at your own risk.I'm using Mobile-1 4T Racing Full-Synthetic 10w40, with the BRP filter.
I have about 2500 miles on the bike since I put it in, and its running great.
Mobil-1 4T Racing is JASO MA, wet clutch primary rated, and after speaking to a tech on the Mobil-1 tech line it meets or exceeded all the BRP requirements, straight out of MOM.
For what its worth.
For what its worth.
Don't go by the color of the bottle, go by what the label says. that's the only way to know for sure.I am thinking the new mobile one came out in Black and the old ones were grey...just bought a couple of cases of grey.....with a really big discount...just the way I like it...
Thanks so much for the info...
