One Legged Willie
My ipod is switching to the aux mode while driving. It worked well for two or three days on the rode and just started switching again while driving around town. Any one have similar issues? Thanks
I had the same problem but it was with my IPhone and the fix was rebooting the phone. So far it is still working :yes:If you have someone close by with a Spyder try checking your cable and IPod on their machine.
The connector is partially to blame as well as the iPod OS, it's just flaky at times. I see the same issue with every vehicle I have an iPod connector to (4 different makes, same iPod). The simple fix is to unplug then replug the iPod, it reconnects every time and works until the connector gets juggled loose a bit or the iPod decides to lose its mind again. Replacing the cables and radio are a waste of time, the iPod interface is not stable, never has been.
I don't think my pod is getting a charge while connected and the :spyder2:is running nor will it charge while :spyder2: is at rest. Isn't it supposed to charge under both circumstances?
To support the IPod I use an old soft eyeglass case, the kind you slip the eye glasses into from the end. I used Velcro to mount it up high in the trunk. The IPod then just slips in the case and is supported and protected better from vibrations.
