Installing the Hitch and wiring
bluestratos
I have a hitch on order, does anyone have the instructions for install handy that they can share with me. I am assuming the actual harnes must plug and pay into an existing connector, correct? And if so where will I find it?
Regards,
Randy
If you are getting the BRP hitch, it will have a good set of instructions included. It will also have the harness. You will need to remove some of the rear cover to get to the connector on the left side.
You might also try a search on here to see if there might be a video to review.
PM me your email address i have the BRP hitch instructions scanned into a pdf. I can find and send later today.
Clair B
I just wanted to presceen the installation proceedure, easier to read here in my comfortable chaire then sitting on the garage floor, lol.
Thanks
If you search hitches you can find some really good ideas. The one I thought was the best was by Scotty. You can hide all of the wires by running the wire harness down the side of the left saddle bag. I found that if you take the grab bar off you can pull the brace far enough apart to be able to slip the plug through so you do not have to run the wiring in the wheel well.
I know it doesn't make sence now but when you get the instructions you will see what I am talking about.
Take your time and have fun. Good luck.
