Yup----- calling dealer tomorrow----- I'm screaming UNCLE!:gaah:
Good advise. Also check to see that the rotors are fully seated on the hubs. With the tires off and the calipers/pads removed, they can slip out of place and fail to seat fully, especially if the studs have a shoulder. This will not only make the pads rub, but will make the tires runout. Debris under the rotor can do the same thing.For the wobble I can only guess... check to see if when you spin the tire by hand the thread is running true. If not... see if the bead seated good on the rim.
While I'm concerned about the constant rubbing----and possible uneven depositing and 'baking' of the brake pad material----- rotors don't actually warp--- that has been well determined to be a myth.
Less techie article:
http://www.examiner.com/x-1060-Orla...9-Theres-no-such-thing-as-warped-brake-rotors
More techie article:
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
I'm just concerned about the constant rubbing--- doesn't seem right to me. I used to be able to spin the tires with the old pads--- no problem... even back when they were new.
Seems the dust cakes in front of the rubber seals and won't allow the pistons to retract fully when you install new pads. You might take an old tooth brush and clean the caliper good. The clicking you are hearing may be the extra friction of the pad on the rotor. Lift the caliper remove the pads. Spray it good with brake cleaner then use the brush to clean any junk that might be caked on the piston stems in front of the rubber keeping the pistons from retracting. A honda mechanic friend of mine taught me to do this every time pads are changed.
Hope this helps you... hate to see them go to the shop... seems many disappear for weeks at the shop. Pixie dust, I think. Ken krb1945
Bingo! Thanks for the ideas--- gee-- cleaning things huh? I shoulda known better!
Tore everything down again--- removed the old pads--- let the pistons come out really far and cleaned everything---- then they retracted much easier.
Re-installed the new EBC pads and the fronts no longer rub like they were. I can spin the tires now and only feel a slight resistance from the pads-- day and night difference from before. From what I've read on some other forums having brakes lightly touch and slow the free-wheel spin a bit is normal.
The rear seems to be rubbing a bit more than the fronts-- but not as bad as before--- plenty of brake dust back there. Cleaned the rotors and going to re-bed again and see how things go.
I did 120 mile trip up to lansing to see Someguy and Qstick7 and NO MORE WOBBLE ! :thumbup: Cruised around 90 for a good while and all is fine again with the front end. Must have been the constant pressure of the pads against the front rotors causing the wobble.
The rotors are still getting hot--- but that's what they do eh? The rear is getting hotter than the fronts for sure.
I'll keep an eye on it --- but pretty sure all is good now.
The pedal does feel a bit soft on the first compression-- but then is normal on the second--- probably need to bleed em......
Thanks everyone for your good input---- learned a lot!
I thought the same thing with the ebc pads, its because the organic compound, I have the gen 3's stilll waiting for ebc's new pads. really watch them and have your back ups if you go on a trip over 500 miles so you do not have a problem like I did. I am sure you keeping track of your miles, it would be cool to have a reference for how long they last for ya.
Leaving Thursday for Sturgis---- 10 days---- 3,000 miles------ hope they last longer than yers---- will take my old ones along just in case.
You may want to also check the parking brake cable at the caliper if the rear brake is hot and or dragging.
There are 2 holes that the cable can be mounted to and if its the wrong one it keeps parking brake activated.
I wont say how I know this :gaah: but I had a really pretty gun metal blue rotor soon there after :2thumbs:
It may also need slight adjustment with new pads as well
I don't see 2 holes that it could mount to....:hun:
