bluestratos
Well got them in the mail and installed immediately. The left (viewed from seat) was more challanging as it has to be done mostly by touch for the top bolt. I used standard 15 socket on a standard 3/8" drive ratchet on the nut and a wrench to hold the head. Working one side at a time it took less than an hour. The manual that comes with them does not even show this style shock but speaks generally about the different settings. The instructions said to scew the rebound adjustment all the way to fastest but after I got them installed I realized the tag that was on the shock opened up and guess what, it contradicted the manual and said to leave the rebound at the factory settings to begin with. I did not count so I started at 15 out of 50.
I took it for a ride and have to be honest, very little difference in comparision to my 2011 shocks. I tried them from 25-75 mph, hit bumps, centerline reflector bumps, tight corners at speed and we had a good wind last evening so I think I got a good feel for that as well. It did seem to react a bit less in the cross wind on the highway and it corned a bit flatter when I pushed it through the corners. It raised the front end... a lot! My head lights were shinning 3" or more higher on the gararge door than before so I had to lower them. I am not sure I like the front being so high, it will help on speed bumps for sure but I think it changes the stance too much. (I did not touch the ride height, it was left per the factory preset).
So wow factor, 2-3 out of 10. Looks, about 5/10.
Now here is the part I am worried about. The manual says to send the shocks in to Elka once a year to change the oil and some seals. Do any of you follow this requirement?
Regards,
Randy
Regards,
Randy
