Installed KN Green Air Filter on 08 RS SE5 ?????
Crisis
Installed the above with stock exhaust, getting some mild popping, already have the Honda exhaust gaskets. Is this the wrong filter?
thanks
thanks
By adding a freer air flow filter you leaned out the air/fuel mixture a little more than the already stock lean mixture.
That's what it's supposed to do. LOL. That mean it works! If the bike runs sloppy, that means you need to add fuel.
thanks
Right filter, wrong fuel mix. More air but not more fuel on a machine that is already on the ragged edge of LEAN means popping for sure.
As said above, the Popping means you're getting your monies worth from the filter. You'll need to add fuel with a JB or Power Commander.
Once you get it dialed in you'll get better throttle response, more HP and, believe it or not, better fuel mileage. That's because you're actually making more HP with less fuel.
Another little known advantage is a cooler running engine.
Of course if you are always whacking the throttle your fuel mileage will suffer but the smile on your face will more than make up for a few more dimes at the fuel pump.
GREEN FILTER
thanks
I added the Green Filter about 1000 miles ago to my 08 GS SM, my MPG's went up approx. 2....But I have had no issues with poor or different engine running......except for the grn filter and my "cold air intake" , I have no other engine Mods......The only difference we have is that you have an SE....I can't see that making a difference......Mike.................PS the K&N and the Green filter are not the same. You have one or the other.....But it shouldn't make a difference either way IMHO
I added a green filter to a previous RS and the only noticeable difference I had was that it made the bike louder. Possibly better mileage too. But none of the problems you are having.
