Keep a watchful eye on the rubber piece that is behind your peg mounting nut/washer. As you all realize, the IG floorboards mount on top of your OEM pegs and cause your pegs to rotate some especially when mounting your Spyder. I installed the IG floorboards on my 2012 RT Ltd probably 10 months or so ago. A few weeks back I noticed the rubber piece mentioned in the first sentence above on my left peg was torn to the point where I could actually grab a piece of the rubber with my fingers. The right side wasn't as bad. I contacted my dealer hoping for a warranty repair and was told the most likely cause was the floorboards twisting the pegs. Sounded logical to me so I didn't press the issue any further. I also had the Rivco RT Driver floorboards on order which require the pegs to be removed for installation anyway.
Be advised that, per my dealer, the rubber piece is not something that can be ordered and replaced when required. This piece has a part number stamped on it (705003616) which I could not find in the IPB. Apparently this rubber piece is an integral part of the foot peg and the fix requires the peg to be replaced. The pegs run about $78 each.
I took some photos of the rubber piece in question and I'll try and post them, but may not be successful. Sorry can't figure out how to upload pictures using my iPad (the photos are also on my iPad). If your interested in the pictures, PM me with your email address and I'll send them to you.
I'm not saying the IG boards were definitely the cause of the damage to the rubber pieces, but...
