inflation
I carry an old 12v "Bell" tire pump. I modified it to plug in to the battery tender wire. As writing this I realized I have (2) 7.5 fuses in this line. I also carry plenty of 16 and 20 gram air cartridges. Does anyone know how many cartridges it would take to fill Rally size tires up to preferred psi. "Slime" may be nice but what about tire balance problems. My mechanic warned me that they charge an extra $20 per tire to clean out the mess.
$5 at Walmart, but getting harder to find..
Mine is on F3-S, mounted in the frunk area..
Miles42 hi ref tire inflation I have a Draper cordless with digital readout / up to 150 lbs / with light . It reads tire pressure first , then you set it to what you want and it cuts off when reached € 54 from Machine Mart easy to connect to ryker
My dealer installed one on my Ryker before I bought it. I never even asked, they just did it. :2thumbs:
They have it so its even with my Ryker front grill. I used it this past winter for my battery tender.
Thanks for the info. I bought the same one but paid three times as much. Still a good deal IF it works and is durable. I bought a female cigarette adapter to battery tender connection so that I can use it without modifying the connection, in case I meet someone on the road that needs to use it on their car. It is so small that I can add a plug kit and fit it in a cloth bag to store in my little Ryker frunk.
