Ikon Front Shocks - Who Uses 'Em & What Do You Think?
DOR55
Am just climbing down the front shock rabbit hole for my 2023 RTL (Wilbers/BR-JRI/Elka/Etc), and have noticed just a few comments on these while perusing the multiple shock threads on this forum. (Note: I have the Baja Ron Ultra bar and end links.)
Ikon 7613-1006 Spyder RT - IKON Suspension USA https://share.google/QmQzneMg7AxQWAGox
$750.00/pair (including tariff fees), 3 different progressive spring options, 4 rebound settings, rebuildable & revalvable.
Not concerned with rear shock at this time (I know the rear Ikon would have to be imported).
Who has used Ikon and what do you think of them?
In real world touring use, are the other options actually worth the additional $200-$500?
Me: 240-250#'s with gear on, old guy solo rider, fully loaded luggage + 50# seat bag when traveling.
Thanks in advance for any and all info.
DOR55
While I haven't had an opportunity to try Bajaron's shocks, I have used a fair few of the other more expensive options that are available out there (and waaay too many of the OEM noodles!) and while my 2-up riding load might be a smidge heavier than yours, I've found Ikon shocks all round really suit my touring and my fairly aggressive 'non-touring' riding significantly better than anything else I've tried to date!! There's a reason that I recommend Ikon shocks to pretty much every Spyder Ryder I talk to about shocks at every opportunity, and I reckon you could do a lot worse AND spend more money on those others to boot!! ;)
Go On! DO IT! You know you want to! 😁
Thanks, Peter. Great info!
Peter,
Sounds like we may have similar riding styles (as my riding buddy Mike describes it - "Rather Spirited"), and somewhat close riding weights.
I am leaning towards Ikon and am curious
regarding how you have yours setup;
- What springs did you choose?
- What is your normal rebound setting?
- What is you normal spring pre-load setting?
Just looking for a good starting point.
Thanks in advance. Feel free to PM me if you don't wish to respond on the thread.
DOR55
It's been quite a few years since I first fitted the IKON Shocks to my RT, and since I'm here in Oz (where they're made) and I regularly visit their part of the Country, I actually went to their factory/workshop and we went thru a few iterations to get my set-up right for me/my riding, loading, etc... So given the passage of time since and the increasing ability of my 'forgettory' function over that of my 'memory' function, I'm sorry, but I really can't remember. :( However, I do have a vague thought that my rebound settings are on 2... or is it 3?? There again, maybe it's 2 up front and 3 on the rear, or is it the other way around?? :unsure: I'm pretty sure it's somewhere there, sorta in the middle tho. :rolleyes:
Anyhow, regarding actually getting you that info rather than vague thoughts/guesses - I'm also not near my Spyder atm, and I'm not at all sure I can read any of the necessary off the shocks/coils themselves while they're fitted (especially the rear info) but I'll have a look later and see if I can get any of it for you and post it up here later today (unless I forget, of course! 😋 Damned forgettory! 😆)
Peter,
No worries, I'll talk with the US distributor before ordering.
BTW - I definitely understand forgettory (I am a well seasoned pro at it...).
Ride Safe,
DOR55
I had a bit of a crawl around out there, and yes, the dial on the fronts is set to 2, the rear I reckon is on 3 (odd angle, but I'm sure it's not a 1, a 2, or a 4! 😋) and the only things I can see on the shocks themselves well enough to pass on looks like part numbers (?) that I may've written on myself with a paint pen when I fitted them some time back... :rolleyes:
On the fronts, that paint pen marking shows 7613-1006; on the rear (and this was a bit easier to get cos it was down on the well exposed bit & almost certainly in my writing!) it shows 3610-1084 on one line, followed by 0723 underneath that on the next line. For whatever it might be worth, there's about 18-20 mm of clear thread showing below the bottom of the adjusting collar on each of the front shocks (same length each side, I just couldn't get a good angle to get an exact measurement :confused:) and on the rear, that clear thread below the adjusting collar is 35-ish mm. ;)
I dunno if that'll help you any, or even if it's the real part numbers, but that's all I could see on the exposed parts of each shock body... and the top bit for the rebound dial reading was from what I could see by shining a light onto an extendable mechanics mirror and reading whatever it reflected into another mirror! Soo, I'd say it's a 'best guess' rather than anything exactly definitive, but hey, it's all I could get without getting soaked in the rain &/or pulling panels off, so that's all you gonna get today! :p
Like I said earlier, these IKON shocks have worked really well for me over a few years now, and I've used their shocks for a lot of miles on the Spyder and other vehicles very successfully over quite a few years, saving myself a heap of money in the process. And I've never had one of them fail &/or 'wear out' on me or need rebuilding, unlike the OEM cheese sticks (and I can tell that one of them failing due to crap metal/welding when the speedo is showing well into 3 digits can be more than just a little bit 'attention grabbing'!! :oops:) &/or some of the more expensive alternatives. Over to you. (y)
DOR55
You do not need to speed that kind of money. Adjusting the air pressure will give you a better ride. I am a very aggressive rider and I have tried a lot of settings and found air pressure to be the most effective.
Thanks for the info, exbrc1!
Excellent Info. Peter.
Thanks for going the extra mile, it is truly appreciated.
Thank You!!!!
DOR55
A little history here. Koni shock absorbers use to be made in the Netherlands. Koni Dial-a-Ride shocks were the way to go as an upgrade for many brands of both Japanese and European motorcycles up until the 2000s. They were a highly respected manufacturer for both performance cars and motorcycles. Respected factory automotive race and rally teams used Koni shock absorbers.
Then Koni decided to exit the motorcycle market to concentrate on the higher volume automotive and industrial businesses.
An Australian company bought the intellectual property, the designs and some of the tooling to start manufacturing again, but this time in Australia. As just a play on the name I guess, they called the new brand Ikon.
So, today Ikon shocks are pretty much a direct descendant of Koni dial-a-rides and other Koni types.
If you like the simplicity, reliability and rebuild-ability of Koni shocks, which were very good in their day, then Ikon shocks will be much to your liking. They've made improvements over the years too. For the kind of vehicle the Spyder is, I think they are perfectly suitable, very reliable and certainly good value for money. I had Koni Dial-a-Rides on the rear of a BMW R100 for nearly a decade and many, many tens of thousands of miles of riding, largely two up, and they lasted all those miles without ever a problem. I had Ikon brand shocks on the rear of my 2018 Triumph T120 and they were vastly superior to the stock items.
Can Am has used a variety of vendors over the years for it's shocks on the Spyder and I rather suspect the Ikon shocks will be much superior to any of the stock items. The Ikon shocks will likely be very robust, long lasting and perfectly fine in terms of performance. They can also be tailored to your needs which is definite advantage.
A little history here. Koni shock absorbers use to be made in the Netherlands. ...
It wasn't just 'an Australian company', it was the Australian company (well, really it was a 'family' ;)) that'd been importing Koni shocks into Oz since the mid/late 60's; then with Koni & other shock brands, moved on into developing, repairing, and modifying them for specific/specialist applications in the mid 70's; until 2000, when Koni decided to drop the 'motorcycle' side of their shock business to concentrate on the more lucrative 'car' market and sold the entirety of their motorcycle business to the same people who'd been operating the Oz side of their business here for 30+ years. So that same family/team who'd been 'the' Oz side of the business from the very start, finally rounded out the entirety of the motorcycle shock business, starting out being the importer of Koni shocks into Oz, moving on thru being the distributor, servicer, applications developer, motorsport suspension tuner, then in 2000 becoming the manufacturer/owner of that part of the Koni business, rebranding them as IKON Motorcycle shocks, and not looking back since! (y)
Yes, I didn’t know about the Oz operation until Koni made their decision to get out of the motorcycle suspension business. I’m glad it was a family and team affair, they all have a lot to be proud of.
