wa3wheels
shock setting ?
I have installed Ron's bar, Question being what has been the average setting of the adjustable shock ring?
I had mine on top notch prior to install.
If you use a jack to life the RT please make sure you set the Spyder back down on jack stands. You will be applying a lot of force moving the frunk, etc that can make the Spyder unstable. :yikes:
The new anti-sway bar does make the corners flatter but don't forget the improved ride. If you have increased the shock settings to overcome the leaning in the corners you will be able to go to a lower setting. I found the improved ride was worth as much to me as the improved handling. The roads around Illinois are not the best.
