ICon on RT instrument panel
dg110270
What is the icon below the gas gauge mean? Looks like flags on a golf course with the letter A. 2019 RT limited. Sorry pics are turned on it’s side.
I'll take a guess (not having seen the icon in person) that it has something to do with distance to destination - or how long your next putt will be! Doesn't the owner's manual mention it?
Distance of travel, in this case till empty or at least when it thinks you should fill up with gas again..
That icon is showing you that you have selected the Trip A trip meter (see attached, top right column). You have the choice of selecting either Trip A, Trip B or Total.
You can switch between either trip meters or total in the Stats when you go to clear them when gassing up. When you're in one of the tabs (Trip A or B or Total) you punch the joystick up and that makes that meter show up in the main screen. The flag icon seems to indicate a trip number. Can't wait to see what else is new.
The 124.1 number is how many miles before you need to refill the tank. (approximately of course).
The 100.1 number is how many miles you have driven on the "A" register since you last zeroed it out.
The icon indicates you are using the "A" register. If you switch over to "B" it will show the icon and B.
