Hi Seger, and welcome to posting on the Forum. :clap: If your Euro-Spec Ryker is anything like our Australian/NZ Spec Rykers are, I reckon that you'll find once you get in to actually working on this, you'll just hafta remove the bits you
DON'T want, and plug in the bits that you
DO want!! :thumbup:
I say this because these things are effectively all made in the same way if not also place, and on our Oz spec Spyders & Rykers, which are
VERY similar to the EU Spec Spyders and Rykers, all the extra bits like those '
independent blinkers' that you have (we have them too) are
Plug'n'Play add-ons to the same basic wiring loom and frame assembly etc!!
hyea:
So to fit those lights here, all that's usually needed is to take the 'independent blinkers'
OFF;
UnPlug them from the main loom; and then
Plug In the a/mkt lights in exactly the same way they specify for the North American Spec Spyders/Rykers! I don't believe you'll need to worry about getting any '
extra' plugs or connectors - once you've got your EU Spec lights
OFF, simply follow the directions from Slingshot to connect up their lights with the parts/wiring that they usually provide, cos if your Ryker is like our Rykers, all the wiring will still work without those extra 'independent blinkers' you get to meet your local regulations anyway! :2thumbs:
Only you might want to watch out for that - sure, you can take them off, but will your Ryker be legal on the roads over there?? :dontknow: Here in Oz, we have pretty stringently applied (Nationally enforced) Australian Design Rules plus local State & Territory Laws that call for all these extra bits, and if we take them off, we run the risk of being fined; of the bike being 'defected' & not allowed to be used on the road until repaired (ie. trailer it home/to a place of repair! :sour: ); or if it's considered a serious enough defect/danger &/or you've been caught being naughty like this before, your bike may be impounded & possibly even crushed for multiple repeat offences! :yikes:
So be careful what you do before checking with your local Authorities, you might find those 'independent blinkers' are mandatory where you are.
Just Sayin' :lecturef_smilie:
