I need help installing Spyderpops Cyclops and A arm LED's
Rukpub
Hello, I received my spyderpops cyclops and A arm LED's for my 2012 RT SE-5 but somewhat confused about how to install both at the same time. Do I need one power bridge or two? Or is there a power bridge on each A arm, and one to connect the cyclops as well? I thank you in advance for your help.
POWER FOR LED
The power for the TIP light on the fender is in a small harness under the plastic cover on the upper " A " arm...I don't see any reason why you can't tap into that as long as you aren't going to have the LED's on a separate switch.....They will be on all the time........I'm not familiar with the CYCLOPS, but you should be able to use the same power wire,.....Didn't this come with instructions ?????...........Mike :bbq:
look for a connector by your A arms and use that for you power tap. Not sure if you bike has the connector by the A-arm??
You can tap both light into that..But not sure about what you have..
