Welcome to posting Capt Currie. You'll probably see the notice telling you that I've moved your post out of the
Spyder General Discussion area and what was really a 'not very related'
Spyder discussion thread into it's own thread in the
Ryker discussion area, so I hope it's not too confusing. This is a much better Forum area for this discussion on your Ryker tho; no harm, no foul, and it's all sorted, I hope.
As always with these
EXTREMELY power hungry machines, you should check the Battery
FIRST!! Cascading errors like those generally mean the battery is dead or dying, &/or at the very least, not up to providing sufficient power at the same time as meeting all the starting loads AND providing all the needed power to run all the necessary sensors, electronics, and computers!!
So check the battery leads & terminals, making sure all the cables are good & the connections are clean & tight; fitting star washers onto the terminal nuts to ensure they remain that way while you're doing these checks is a great idea; make sure your battery is fully charged; then
Load Test the battery - only because these things are so power hungry, if the voltage drops below
12 volts while it's cranking, your battery is no longer really up to the task. Yeah, I know that anything over 10.5v or so is 'normally' considered 'good' for a battery, but not on these Spyders and Rykers! They need more power than most other machines, and
your battery supplying anything less than 12v under starting loads means something is going to suffer!!
Only once you've confirmed that you've got a good and fully charged battery capable of providing sufficient power should you bother looking for anything else!
Just Sayin'
