I have No Power to the replacement analog gauges.
pslawing
GOS member (Girls On Spyders)
I replaced the analog gauges last year, have worked fine till this week. All of a sudden quit working, both of them. All other electrical seems to be fine. All fuses seem to be fine. Checked wiring to gauges and there is no power. Any thoughts from you guys? thanks ahead of time.
attachment.php
Have you had the panel off, to check your connections yet? :dontknow:
(Sorry: I HAD to ask... :opps:)
As I recall; they either "fly, or die" together. If one quits: they BOTH quit...)
Maybe you should have left the old OEM ones in. Remember, don't mess with it if it ain't broke.
A lot of folks here are always changing perfectly good things on there Spyders and then start having problems.
Good luck on your fix.
Jack
Curious. ....
What other work was done back there..?? If all your fuses are good and nothing else is not working then you need to get back there and see if you have a loose connection or cut wire. Did they just stop working all of a sudden or after work was done..?...:dontknow:
Yes installed spyderpops cyclops will go back and see if something is amiss.
thanks
If it was working before, then recheck your work and look for loose connection. Use volt/amp meter for proper connections. Good luck.
