Recently did an oil/filter change (every 4K) and I always grease .....or attempt to grease....the front fittings. 2 or 3 of the eight fittings take grease and rest won't, despite pushing the nozzle in as hard as possible. :banghead:
I
If I remember correctly....it was sometime ago. Someone discovered the threaded portion of the zerk was longer than the debth of what it was being screwed into. End result was the zerk bottoming out on the bushing. Might take a look, and if that's the case. Relieve a little of their length.
I didn't even know there were grease fittings. lol
Good thing I only have 800 miles on my bike so far. :shocked:
I greased mine at 600 miles with synthetic grease from BRP.
Two or three grease gun nozzles?
My grease gun has a twist nozzle fitting on the end, it adjust to many types of zerks.
Never ran across one it hasn't fit yet. :dontknow:
I bought right angle zerks but when I went to change them there is no room to install them unless I take the A-arm off the bike. I may be able to get them drop enough if I pull the shock and disconnect the sway bar, any one know?
Did you find a nozzle for your grease gun that fit over the top of the zerks? On mine the BRP zerks stuck straight up and after buying two or three nozzles for my grease gun that snapped on over these, and none worked, I removed the upright zerks and put in some 45 or 90 degree type that I could use a regular straight push on nozzle. Some of the zerks were nearly impossible to get out/in and I hesitate to even fool with them again, but if I can find a nozzle that fits over the OEM zerks, I'd put them back in instead of fiddling with my replacements.
My 90's won't even turn, the hit on the way around. I will have to take another look.
This looks like it will work. So before I go out and buy one has anyone tried one of these?
