PeterKelly
I have seen a couple of posts about fasteners with BRP’s Loctite being really tough to deal with but had not had any experiences of my own till today when I was attempting to install floorboards on my F3 S.
Removing the rubber foot peg inserts requires removal of 2 12mm bolts on each side. Easy…..right?
Not so fast - these bolts extremely hard to get moving. I was very conscious of not stripping the heads, using the correct size socket and a short ratchet. I got them moving a couple of turns and then the heads snapped off. This happened on both bolts on the left peg.
What’s up with using gobs of strong Loctite and cheap fasteners. It’s a sure fire recipe for a disaster. What should have been a simple half hour job turned into a two hour drama.
Perhaps the Gorilla glue and Loctite got into the wrong packaging…. ��
