First of all, I'm from Thailand. In here, there are not any dealer. I got Spyder GS 2008 SM5 from a importer. Some problems I can fix it by myself. But I got 2 problems that need your help.
1. 2 months ago, I got some text in LCD, "Brake Failure" and the brake indicator shows. I tried to find how to solve this problem in this forum, I got some. but when I tried to do press brake pad to reset it. Nothing happened. How can I fix it? But I can ride, nothing wrong.
2. Yesterday, I got the new problems, "Bad Key". I used the same key that I ride everyday but I could not start the engine. When I turned on the key, LCD was bright. So I pressed Mode button to start. LCD showed text; "bad key". T tried the use the 2nd key the same thing happened. I use the original keys.
Can you help me to fix these problems. Now I cannot ride the spyder anymore.
Thank you for your help.
