I'm having difficulty understanding this:
Losing pressure. Hard to get in first gear.
The SE6 clutch is
ENGAGED with HCM oil pressure. Per the Service Manual
Clutch clamping with hydraulic force via clutch piston – hydraulic pressure is generated by the HCM. The clutch is disengaged by reducing hydraulic pressure to clutch piston, clutch springs open the pressure plate.
Are you saying after shifting into 1st, the Spyder does not move forward as you increase throttle? Or are you saying the Spyder does not shift easily from N to 1st?
Next question: with the engine off after releasing the parking brake, can you push your Spyder forward and backward?
Next question: what was the measured HCM line pressure while the engine was running and in 1st gear (I assume the dealer used BUDS)?
If the dealer didn't provide you this pressure information, you need to measure it. Below screw #4 (tightening sequence) of the HCM filter is a standard 3-wire pressure transducer that measures clutch engagement pressure (0 - 174 psi). One wire (VT/BU) is Ground, one wire (VT/GN) is Vo bias voltage and one wire (YE/WH) is Vs sensor voltage. Turn the ignition on and carefully using needle-type connector back probes, verify the function of each wire. Vo is probably 5V although it might be 12V and Vs will be 0.5V although if Vo is 12V it will be 5V.
Once you have verified the wire functions, connect one probe to Ground and the other to Vs. Start the engine. Vs should increase albeit not by much. It may be a 200psi transducer although more likely 300psi. For a 5V Vo 200psi transducer, the clutch pressure is ((Vs - 0.5V) / 0.02) psi. 5V Vo 300psi transducer is ((Vs - 0.5V) / 0.03) psi.
Shift into 1st and increase the throttle to 1500rpm. You should be seeing Vs at least 2V probably higher.
If Vs reaches 2V or more, then your HCM probably isn't the problem. Your problem is more likely the holding nut for the clutch assembly has loosened and backed out a turn or two. Expensive labor for disassembly is still required but expensive parts shouldn't be needed. Do a search for this problem -- it has occurred before.
If Vs doesn't reach 2V then yeah I think you're going to need some expensive parts.
