Hr Trip and Hour meter stopped
amusher
Anyone know why my Hr Trip and Hour meter on my 2012 RS stopped registering?? I reset the Hr Trip to 0.0 but now it doesn't read at all.. Everything else on the dash is fine....
stopped working
Two things come to mind .... Way back when, there was info about the Odometer only registering up to a certain mileage ....and if you didn't do some-kind of reset prior to this happening the odo would lock ...............check what your setting is on the A - B mileage reading .... on mine if it's not on PAUSE nothing registers except the over-all mileage total .......... good luck .......... Mike :thumbup:
My mileage odometer both A and B work fine.. Clocks works and overall mileage still registers.. Only the Hr Trip and Hour meter stopped registering.. I can't get anything to 'pause'...Someone else mentioned that but its not the odometer..
That mileage was 62,000 and change (100,000 KM). If I remember correctly, that got solved in 08 or 09. Dealers then were supposed to correct the "glitch" through BUDS.
62,000 mi.
Thank you, You have a better memory than I :roflblack::roflblack::roflblack: .......... But maybe they didn't !!!!!! ........ Mike :thumbup:
