HowTo: Remove lowest LH front panel to change oil & Filters. Mickc
Side panels..!!
Depending on how much you want to remove. The lower panel covering the oil tank has three twist fateners. Upper front, lower front and one in the upper rear of the panel (tucked under) if you want to take off the bottom panel there are torx scews on the outer edge and two 10 mm bolts on the bottom up against the center frame. If you are taking the lower kick panel off you need to take off the center and rear panel to get to the upper midfle torx. Hope this helps...:thumbup:
